Data assist image gallery
I wondered if there was an image gallery which would work with Data Assist?
Thank you
John
Thank you
John
any image gallery that will work with static images can also work with Data Assist, the only real difference is whether you use a repeat region to loop through the recordset on the page, or manually add image tags
to simplify the concept, data assist is really just a tool for managing information in a data base.
The information stored in the database can be image names and descriptions.
a recordset can be created to return the image information stored in the database by Data Assist, and Displayed in a repeat region.
