Create Product Catalog - Database Preset
Thread began 8/09/2012 8:44 am by elevy388997 | Last modified 8/09/2012 11:04 am by Jason Byrnes | 707 views | 3 replies |
elevy388997Beta Tester
I am starting to create a dynamic site and in the very first window that opens up with the DataAssist: Create Pages wizard, I chose Product Catalog and it says the products table I currently have selected doesn't contain all the columns as the Product Catalog preset.
I am wondering which columns the Application Type Product Catalog preset has, that I do not. I imported the free eCommerce database.
If you select the option to have the wizard create the table for you, then go to the Manage pages tab and edit the Configure Field Settings, you can see a listing of the database columns for the preset.
Starting from ProductRetailPrice to the bottom, I added to the eCommerce Database match the preset database. I just want to check that the datatypes and default values are correct:
(attached)
here is the SQL used to create the table:
CREATE TABLE `Products` (
`ProductID` int(12) NOT NULL AUTO_INCREMENT,
`ProductSKU` varchar(50) DEFAULT NULL,
`ProductName` varchar(100) NOT NULL,
`ProductPrice` float(12,2) NOT NULL,
`ProductRetailPrice` float(12,2) DEFAULT NULL,
`ProductShipping` float(12,2) DEFAULT NULL,
`ProductWeight` float(12,2) DEFAULT NULL,
`ProductCartDesc` varchar(250) DEFAULT NULL,
`ProductShortDesc` varchar(1000) DEFAULT NULL,
`ProductLongDesc` text,
`ProductThumb` varchar(100) NOT NULL,
`ProductImage` varchar(100) NOT NULL,
`ProductUpdateDate` timestamp NOT NULL DEFAULT CURRENT_TIMESTAMP,
`ProductStartDate` datetime DEFAULT NULL,
`ProductEndDate` datetime DEFAULT NULL,
`ProductStock` float(12,2) DEFAULT NULL,
`ProductLive` tinyint(1) DEFAULT '0',
`ProductUnlimited` tinyint(1) DEFAULT '1',
`ProductDigital` varchar(250) DEFAULT NULL,
`ProductMaxDownloads` int(12) DEFAULT NULL,
`ProductNonTaxable` int(1) DEFAULT '0',
`ProductTitle` varchar(100) DEFAULT NULL,
`ProductMetaKeywords` varchar(255) DEFAULT NULL,
`ProductMetaDescription` varchar(255) DEFAULT NULL,
PRIMARY KEY (`ProductID`)
) ENGINE=MyISAM DEFAULT CHARSET=utf8
