Year field problem
Thread began 8/08/2012 7:13 pm by rjbayerl157031 | Last modified 8/09/2012 10:33 am by Jason Byrnes | 966 views | 3 replies |
rjbayerl157031
Year field problem
I have a db with tables which have a field intended to be a four digit year. When I try to input a value I get the datepicker which makes it a full date, not just a year. How do I get around this? In the tables the field has a type of year(4).
This same problem happens with the update page.
Dick Bayerl
A date picker filed is not intended for picking only the year, instead, use a select list and populate the select list with the years.
rjbayerl157031
Year Field Problem
Thanks. Made it a text field for entering a four digit year.
That will work as well.
