Update information not showing
Thread began 8/08/2012 8:52 am by mouse426912 | Last modified 8/09/2012 12:23 pm by Ian S | 365 views | 3 replies |
mouse426912
I have set up admin pages to display staff members with the following fields:
Name(text), Photo(char 55), Story1(textarea), Story2 (textarea), listOrder (int 11)
I applied File manipulation to the Photo field so that photos can be uploaded. This is something I have done before with no problem.
When I insert information, the photo field populates, the listorder field sometimes reads the input and sometimes does not.
When I update, I lose the photo field information and the listorder field goes to 0.
I am getting this error on the Results page: Notice: Undefined variable: totalRows_WADAstaff in /var/www/vhosts/brasslanternnantucket.com/httpdocs/newadmin/staff_results.php on line 25
No errors are being reported on the Details, Update or Insert pages.
I have attached the 4 pages
Archive.zip
Ian S
Regarding the photo information the order of your code is wrong.
Your update code is running before your upload code runs so you will be updating an empty value into the database. If you have a piece of code that refers to a variable in other code, that other code needs to run first otherwise the variable does not have a value.
Also, as you have a redirect in your update behaviour, the upload code will never run because you are telling the page to redirect before it gets to it.
Try correcting that for starters and see how you go from there.
Cheers
Ian
mouse426912
Thanks, this worked but not completely
Your instructions did, indeed, solve the photo update problem but not the listOrder field problem.
When I went into the code on the Insert and Update pages, for some reason the listOrder field was not listed in $WA_fieldNamesStr or $WA_fieldValuesStr. I hand coded it in and it works now. Not sure why the listOrder was not picked up in the page generation. It was listed in the DataAssist Wizard and showed on the Details Page.
Thanks for your help
Ian S
Great stuff! Glad to hear all is now OK.
Cheers
Ian
