Problem with dynamic field
Thread begun 8/07/2012 10:39 am by mouse426912 | Last modified 8/07/2012 11:53 am by mouse426912 | 1732 views | 4 replies |
mouse426912
I have a table where one field is dynamically linked to another table. In DataAssist, I created the pages, Insert, Update, Details and Results. The Results, details and update page are fine. The Insert Page is blank. Any clues?
a blank page means that a php error is occurring but error reporting is turned off.
to turn error reporting on, add the following code at line 1:
error_reporting
(E_ALL);
once we know what the error is, we will be able to troubleshoot the cause.
NOTE: When attaching files, please compress the PHP file to a zip archive and attach the zip file.
mouse426912
Error Messages
Here is the error messages I'm receiving:
Notice: Undefined variable: database_BLantern in /var/www/vhosts/brasslanternnantucket.com/httpdocs/newadmin/photos_insert.php on line 5 Notice: Undefined variable: BLantern in /var/www/vhosts/brasslanternnantucket.com/httpdocs/newadmin/photos_insert.php on line 5 Warning: mysql_select_db() expects parameter 2 to be resource, null given in /var/www/vhosts/brasslanternnantucket.com/httpdocs/newadmin/photos_insert.php on line 5 Notice: Undefined variable: BLantern in /var/www/vhosts/brasslanternnantucket.com/httpdocs/newadmin/photos_insert.php on line 7 Warning: mysql_query() expects parameter 2 to be resource, null given in /var/www/vhosts/brasslanternnantucket.com/httpdocs/newadmin/photos_insert.php on line 7
I've attached the zip file.
Thanks.
move the code from line 11:
<?php require_once('../Connections/BLantern.php'); ?>
to line 1.
mouse426912
Presto! Thanks - all fixed.
