error while checking stats
Thread begun 8/07/2012 8:46 am by chris358388 | Last modified 8/07/2012 1:31 pm by Jason Byrnes | 919 views | 1 replies |
chris358388
My client says they have not received the last 2 emails they sent out with power messenger, they checked the results and received this message. I am assuming this might be part of a larger problem? Messenger has been working ok for almost 2 years on this server.
The SELECT would examine more than MAX_JOIN_SIZE rows; check your WHERE and use SET SQL_BIG_SELECTS=1 or SET SQL_MAX_JOIN_SIZE=# if the SELECT is okay
Any Ideas? Thanks.
