Data Bridge 1.07 JS Error
Thread begun 8/07/2012 2:39 am by Ian S | Last modified 8/07/2012 11:32 pm by Morgan | 3438 views | 8 replies |
Ian S
Hi Guys,
After installing DB 1.07 I get the following error when I click the Behaviours drop down.
Ive done the usual, MacdatCache and resetting workspace etc.
It does only appear the first time its clicked when Dreamweaver has been opened. After that it drops down fine.
Procedure for updating was uninstall 1.06 then install 1.07
This happens on both CS5.5 and CS6 (two separate machines) on the MAC.
Cheers
Ian
John LangerBeta Tester
Works fine for me.
My proceedure was to uninstall DB 1.06
Delete the WinFileCache
Start Dreamweaver
Close Dreamweaver
Install DB 1.07
Start Dreamweaver
I do the same procedure every time I install a new or update a WA extension.
This is on a Windows 7 system (I realise you're on a MAC) with DW CS6
Morgan
Same problem here, unistalled, deleted Config-folder, but i get the same Error, on Win7x64/CS6
Can“t even find the file on my PC after doing a search (including hidden files etc): WA_DocumentEditing.js
And i get a new JS error after ive unistalled DB 1.07 see image nr 2 when i close DW (with no DB installed)
Installing 1.06 again see if that sort the 2 problems out.
Yes that fixed the problem, i saw that in DB 1.07 there was 2 new behaviors in the Webassist panel that not is in 1.06.
/Morgan
MikeyT
Same problem here as well. OSX 10.7.4 / DW CS6. It only occurs the first time I startup DW.
here is a copy of the Configuration\shared\WebAssist\Library\WA_DocumentEditing.js file that should correct the error.
for help locating the users configuration folder, see the Common installation issues page:
common_installation_issues.php
MikeyT
Yep, seemed to work. Thanks!
you're welcome. It will be fixed in version 1.0.8.
Ian S
+1
Thank you Jason
Cheers
Ian
Morgan
Thank you Jason! :)
