Repeating tables fails
I have made several attempts at following the instructions of "Using Repeating Tables in Data Bridge". The text "Your Repeated Content" does not show in the design window. What I see is a very condensed table with nothing visible in the cells (see attached). On each attempt, I would delete the itemlist.php file and start over. On one of the attempts, I did see the text mentioned above and replaced it with the binding but that file is lost and I can't repeat it. Thanks.
