Errror message on contact form
Thread began 8/05/2012 5:30 pm by sandy170299 | Last modified 8/07/2012 12:01 pm by sandy170299 | 732 views | 6 replies |
sandy170299
Please refer to this page: contact-us.php
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home/lutche5/ribbonfair.com/siteHeader.php:110) in /home/lutche5/ribbonfair.com/webassist/form_validations/wavt_validatedform_php.php on line 3
Any ideas how I can get this message to go away? Thanks!
the error is caused by output between php tags.
this section of the error:
is saying that the output is on the siteHeader.php file near line 110
See the following thread for details:
showthread.php?t=19285
sandy170299
This is the block of code that is on line 110:
<style type="text/css" media="all">
@import url("CSSSculptor/2ColumnFixedLeftSidebarHeaderandFooter_CaboSunset_css/screen.css");
</style>
Do you see what the problem is?
Thanks!
sounds like there is php code after the HTML code that should not be there. I would need to see the full page code in context though.
sandy170299
Hi, Jason. I am attached the pages for you in a zip file. Thanks!
FYI, using Google Chrome, I'm unable to use the interface that allows me to attached/upload a file to this thread.
contact.zip
it looks like you are adding the contact.php page to the contact_us.php page as an include using require_once() and doing the same with the siteHeader.php page.
this wont work.
the problem is this:
in both the siteHeader.php and contact.php pages there is php code that must come before any HTML output.
the format of the contact_us.php page will be something like this:
<!doctype....>
<html>
<head>
<title>page title</title>
</head>
<body>
other HTML Code
[include the siteHeader.php here]
some other HTML code
[include the contact.php here]
rest of HTML code on the page
so by using require_once to include the site header and contact pages as includes, it will be adding php code to the page after HTML output which is causing the issue you are experiencing.
the work around for this is to use Framework builder plugins. Framework builder plugins will automatically strip the php code that is before the doctype tag of a page and add that code above the doctype tag of the page it is being plugged into to prevent this from happening.
I see in the contact page you sent that you have stripped out the doctype, head, title and other tags, you shouldn't do this when using Framework builder plugins. It is a valid technique in cold fusion and ASP to use includes, but not in PHP.
sandy170299
Thanks, Jason. I'll see what I can do with it.
