CS3 Compatible
Thread began 8/04/2012 9:35 am by evansg7124312885 | Last modified 8/06/2012 7:54 am by Jason Byrnes | 1327 views | 1 replies |
evansg7124312885
CS3 Compatible
I received an email from WebAssist on 6/26/2012 that said you had given backward compatibility to Design Extender, Data Bridge, and ECart. The Getting Started Guides for DE and DB still say DW 4 required. I have a Windows machine that has CS3 and Windows 7 Pro. I would like to know before I remove the existing extensions and replace with the newer versions that the backward compatibility statement in your email is still accurate.
Thanks and I will talk to you later,
Yes, Design Extender, eCart 5 and Data Bridge are compatible with Dreamweaver CS3.
