100% width menu with 40% width textfields?
i would like to know if it's possible to build a 100% width menu with formbuilder? i have tried it but the result wasn't so good.
thx for your quick respond.
CSS Form Builder is not used for creating Menus.
CSS Menu Writer should be used for this instead.
Menues created using Percentage values for width will not work correctly in Internet Explorer. To create a menu that is properly compatible with IE, you will need to use Pixel based measurements for the menu. IE does not properly support percentage based widths for inline elements.
Sorry i want to build a 100% form of course. How can i do this with css form builder?
to change the css properties of the form, Click the Edit button under the design Selection list.
For changing the width to use percentages, you will need to go through each selection to edit the width for the form, and various element types.
the same caveat for using % and IE exists for forms as is for menus, IE does not work well with % based widths.
It is still not working. What can be the reason?
in what way is it not working?
please post more details and a link where i can see the problem.
