You have an error in your SQL syntax;
Thread begun 8/03/2012 1:27 pm by john70964 | Last modified 5/14/2014 8:02 am by Jason Byrnes | 4222 views | 4 replies |
john70964
I am using the dataAssist wizard into a mysql table.
The test data I am using goes into the table correctly.
I am getting an error
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'Condition, str_Currency, Price, MyFName, MyLName, Myemail, MyWebSite, MyTel, Des' at line 1
I found other postings on this and changed Condition to Condition1 on the page and in the table but I still getting the same error
Can anyone think why I am getting this error please?
I am attaching a zip of the file
Many thanks
John
your table has a column named Condition. Condition is a reserved word and should be avoided for use as a column name.
See the following page for a full list of reserved words for MySQL:
reserved-words.html
john70964
Thanks for the answer.
That was interesting
I had field Condition in the table and the dataassist form.
I changed these to Condition1 but still had the error.
I did a find replace throughout all forms and only then lost the error.
superpac250441
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '' at line 1
Hi Jason,
Please can you help me with this error message. See attached file. Many thanks
