Unable to add images to galleries
When uploading an image to a gallery, I get the following error: ERROR: Missing a temporary folder.
How do I fix this problem?
this is a problem with the upload_tmp_dir setting in the php.ini file on your server.
you will need to contact the host to have this issue corceted. they will need to create an upload temporary directory on the server for you to use and update the php.ini file to point the upload_tmp_dir to the folder they create.
The gallery was working correctly up until today.
Is there a way that the client who maintains their own gallery could have deleted the directory?
more likely there was maintenance done on the server by the host, maybe to update the PHP version that is the cause of the problem. the error you report points to the upload_tmp_dir setting in the php.ini file on the server, you should contact the host.
