Redirects stopped working?
Any idea why all my redirects worked fine on Monday and now today the don't?
no idea why redirects that where working before would stop working.
could be a php error causing the header function to fail. to turn on error reporting add the following code to line 1 of the page:
error_reporting(E_ALL);
is this happening on insert / update pages? or eCart pages?
Thanks Jason,
No errors are coming up. This started happening with all updates, Inserts and deletions of records.
I should add that the forms are included in pages using Framework Builder. But it was working fine. Now it isn't.
The data is correct everytime, just the redirect just redirects to the same page.
Hi Guys
I've suddenly started getting a problem where the redirects stop working.
If I am on a page such as update.php and I update the record and send the page back to update.php the browser reports update.php in the address bar (i.e. the domain name has gone).
Easy workaround for now is to add the domain name into the redirect but something has gone a miss somehow?
Cheers
Ian
Hi Guys,
Just a quick update.
I seem to have fixed this by commenting out the following line for each of the Data Assist behaviours that have a redirect.
//if (function_exists("rel2abs")) $WA_redirectURL = $WA_redirectURL?rel2abs($WA_redirectURL,dirname(__FILE__)):"";
Had a hairy moment today as it effectively destroyed my biggest clients web application, but thankfully commenting out that line seems to have provided a temporary fix.
Cheers
Ian
