dynamically changing a link reference
Thread began 7/31/2012 6:05 am by JamieEff | Last modified 7/31/2012 7:49 am by Jason Byrnes | 735 views | 1 replies |
JamieEff
Am not really sure how to explain this but here goes:
On a clients site, I have created a testimonials pag and am using a recordset to draw the relevant info from the database to display for the relevant testimonial.
Part of each testimonial includes a modal to pop up the actual testimonial.
What I am struggling to achieve is, if I am using a repeat region using 2 or more records, then the pop up 'breaks'
The pop up when using just one record is fine and looks like this:
html:
<a class="poplight" href="#?w=700" rel="popupreference">testimonial</a>
which then displays the following
html:
<div class="popup_block" id="popupreference">Content to go here</div>
What I have been trying to do is to use the content value from the database to dynamically change the 'popupreference' bit using the Content Value from 'Popup Name' eg,
<a class="poplight" href="#?w=700" rel="<?php include('WA_CMS/addtosite.php'); echo str_replace(array("<p>","</p>"),"",WA_getCMSContent($database_PowerCMSConnection$PowerCMSConnection'Clients''Popup Name'false$row_ClientsRS['ContentPageSetOrder'])); ?>">testimonial</a></div>
<div class="popup_block" id="<?php include('WA_CMS/addtosite.php'); echo str_replace(array("<p>","</p>"),"",WA_getCMSContent($database_PowerCMSConnection$PowerCMSConnection'Clients''Popup Name'false$row_ClientsRS['ContentPageSetOrder'])); ?>">Content to go here</div>
Is it possible to achieve what I am trying to do uising this method and if so, what am I doing wrong please?
Jamie
It is posible, but not simple.
the second recordset would need to placed inside the repeat region, and would need to use the first recordset as a filter.
if you need help with this, it goes beyond what i can do here in the forums, i would suggest signing up for a premiere support appointment.
