menu will not show up properly
Please look at my site at principal.htm it should be going across the top like on franklin but it's not for some reason and I can't figure it out. I think I am missing a file or something??? Please help-
Troy
Troy
The menu you are using on that page is cssmw34, which you do not have an include for. You will have to add this to your page:
<script type="text/javascript" src="CSSMenuWriter/cssmw34/menu.js"></script>
<style type="text/css" media="all">
@import url("CSSMenuWriter/cssmw34/menu.css");
</style>
<!--[if lte IE 6]>
@import url("CSSMenuWriter/cssmw34/menu_ie.css");
</style>
<![endif]-->
Add this right before:
<!-- InstanceEndEditable -->
</head>
and the menu should load correctly.
Thanks for the reply. I tried that and it still is not working so I used the template from one of the other grade schools and kept the same menu cssmw33 and it still is not working. That menu works just fine on the other school pages at principal but it will not work for Franklin school. I did make a few additions to the menu using the CSS Menu writer wizard. It seems as if something is missing causing the menu to not show up properly. Please look again at principal and see if you can help me with this problem please!!!
thanks
Troy
Looks to me like you got the issue resolved. Let me know if this is not the case.
Thanks for the help it appears the issue is an IE6 issue but what is strange is that all the prior pages I created using the menu writer appear just fine in IE6 and now the last set of pages do not appear properly. I'm not sure what have changed but do you have any suggestions? The menu looks good in IE7 but not in IE6. If you look at the home page for that set of web pages in IE6 it appears just fine, just not the template pages for Franklin School??? Very Strange-
Troy
home page: franklin
webpage: principal
Check to make sure that you have uploaded the menu_ie.css file to your server in the CSSMenuWriter/cssmw33 directory.
