Checkout way's
Thread began 7/27/2012 7:08 am by Remco209061 | Last modified 7/30/2012 8:19 am by Jason Byrnes | 673 views | 3 replies |
Remco209061
Checkout way's
Hello
is there a solution for other payment ways. In Holland we use for example RaboOmnikassa
if you do a payment you get back an response code succes or fail. I want to use that for the final order confirmation if the payment is right the order is confirmed and the mails will be send. Is this also possible with ecart?
grts Remco
You would need to hand code the checkout procedure to use a gateway that is not included with eCart.
You would need to refer to the api documentation for the gateway you want to use for details on how to create the code.
Remco209061
Hello Jason,
I know, but whats the page after a succesfull payment? Is there a sampele page I can use?
grts Remco
after successful payment, you would redirect to a checkout success page.
