Checkout not working
Thread began 7/26/2012 3:17 pm by Eric Goodman | Last modified 7/27/2012 10:01 am by Eric Goodman | 1687 views | 4 replies |
Eric Goodman
I have a site that was doctored up by you. I had it under my old host provider that couldn't issue independent IP addresses so I masked it with the domain. It made a few problems. I had you try and fix the checkout and now that I moved the site to new hosting, SSL, independent IP and all, when I hit checkout it is redirecting to the old SSL folder. Any way of fixing it. www.shopjewelsforacause.com
Client wanted me to have it working asap. Thanks a million....
the ssl redirect happens in the webassist/plugins/shoppoiong_cart/checkout_form.php file, the following line sets where it goes to:
$testRedirect = "https://".$_SERVER['SERVER_NAME'].$_SERVER['REQUEST_URI'];
it uses the $_SERVER['SERVER_NAME'] variable as the domain.
you could hard code the domain by changing that to:
$testRedirect = "https://www.shopjewelsforacause.com/".$_SERVER['REQUEST_URI'];
Eric Goodman
Checkout issue
I added the code provided in place and it directs correctly now. One glitch I caught when doing a few dry runs on the store: I add a few products to the cart and click checkout. It then comes up with an empty cart. I tried again and it seemed to function fine. I repeated it and it glitched again and then again it worked, so this is kind of resolved? Any ideas?
Thanks for your attention...
i bet you are testing without the www in the URL.
what you are describing will happen if you leave of the www:
when the redirect goes to;
this is a different domain as far as the session cookie is concerned, so a new session is started.
you can use an htaccess rule for your site if it apache hosted to force all traffic to the www address:
force-www-htaccess.html
Eric Goodman
Wow
Thanks a million. Extremely helpful...
