[Bug?] Duplicate SS validation error display for HTML Editors?
Thread began 7/26/2012 11:45 am by Andrew Read | Last modified 7/31/2012 9:12 pm by Andrew Read | 407 views | 3 replies |
Andrew Read
I've had this happen both times that I've tried to create this page, duplicate error messages on a HTML Editor:
<li class="formItem">
            <div class="formGroup">
                  <div class="lineGroup">
                     <div class="fullColumnGroup">
                          <div class="errorGroup">
<div class="fieldPair">
                       <div class="fieldGroup">
                       <span><?php
// The initial value to be displayed in the editor.
$CKEditor_initialValue "".((isset($_GET["invalid"])?ValidatedField("scrubbedIns","SCRUBFIELD",false):""))  ."";
$CKEditor = new CKEditor();
$CKEditor->basePath "../../webassist/ckeditor/";
$CKEditor_config = array();
$CKEditor_config["wa_preset_name"] = "Normal";
$CKEditor_config["wa_preset_file"] = "Normal.xml";
$CKEditor_config["width"] = "392px";
$CKEditor_config["height"] = "250px";
$CKEditor_config["skin"] = "kama";
$CKEditor_config["dialog_startupFocusTab"] = false;
$CKEditor_config["fullPage"] = false;
$CKEditor_config["tabSpaces"] = 4;
$CKEditor_config["toolbar"] = array(
array(
'Bold','Italic','Underline'),
array(
'JustifyLeft','JustifyCenter','JustifyRight','JustifyBlock'),
array(
'OrderedList','UnorderedList','-','Outdent','Indent'),
array(
'FontName','FontSize'),
array(
'TextColor'));
$CKEditor_config["contentsLangDirection"] = "ltr";
$CKEditor_config["entities"] = false;
$CKEditor_config["pasteFromWordRemoveFontStyles"] = false;
$CKEditor_config["pasteFromWordRemoveStyles"] = false;
$CKEditor->editor("efsDesc"$CKEditor_initialValue$CKEditor_config);
?><label for="SCRUBFIELD" class="sublabel" >General Description<span class="requiredIndicator">&nbsp;*</span></label>
if (ValidatedField('SCRUBFIELD','SCRUBFIELD'))  {
  if ((
strpos((",".ValidatedField("SCRUBFIELD","SCRUBFIELD").","), "," "7" ",") !== false || "7" == ""))  {
    if (!(
false))  {
?><span class="serverInvalidState" id="Insert_group_11_ServerError">Please enter a value.</span><?php //WAFV_Conditional SCRUBFILE.php scrubbedIns(7:)
                       </span>
  if ((
    if (!(
false))  {
                       </div>
                       </div>
                          </div>
                     </div>
                  </div>
            </div>
            </li>
Andrew Read
I am also unable to change any settings for this editor, or any others on this page, using the Edit button. When I click OK the changes are discarded.
Andrew Read
For now the solution is to delete the duplicate.
A permanent solution will be available in the next update. :)
