Error Message
Thread began 7/26/2012 8:06 am by hbibizadeh396670 | Last modified 7/26/2012 10:58 am by Jason Byrnes | 556 views | 1 replies |
hbibizadeh396670
Error Message
I made this results page and when I try to lunch it I get this error:
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'Desc, StartDate, EndDate, MakerEmail FROM siteezy_events LIMIT 0, 10' at line 1
What have I done wrong?
Thanks in advance.
Send.zip
you are using the MySQL Reserved word "Desc" as a column name in your table.
MySQL reserved words should be avoided when naming your columns.
see the following page for a full listing of mySQL Reserved words:
reserved-words.html
