Search radio buttons need a third option for "not used"
Thread began 7/26/2012 9:39 am by Andrew Read | Last modified 7/26/2012 3:04 pm by Jason Byrnes | 610 views | 5 replies |
Andrew Read
Not sure if this is personal preference or not, but on the search pages the radio button defaults should have a 3rd option for "not used" that is null. This allows you to 'un-include' them from a search filter.
<label class="radioSublabel_Narrow" for="SCRUBNAME__1">
          <input type="radio" name="SCRUBNAME" id="SCRUBNAME__1" value="1" class="formRadioField_Standard" <?php if (!(strcmp((isset($_GET["SCRUBNAME"])?$_GET["SCRUBNAME"]:""),"1"))) {echo "checked=\"checked\"";} ?>>&nbsp;yes</label>
        <label class="radioSublabel_Narrow" for="SCRUBNAME__2">
          <input type="radio" name="SCRUBNAME" id="SCRUBNAME__2" value="0" class="formRadioField_Standard" <?php if (!(strcmp((isset($_GET["SCRUBNAME"])?$_GET["SCRUBNAME"]:""),"0"))) {echo "checked=\"checked\"";} ?>>&nbsp;no</label>
          <label class="radioSublabel_Narrow" for="SCRUBNAME__3">
          <input type="radio" name="SCRUBNAME" id="SCRUBNAME__3" value="NULL" class="formRadioField_Standard" <?php if (!(strcmp((isset($_GET["SCRUBNAME"])?$_GET["SCRUBNAME"]:""),"NULL"))) {echo "checked=\"checked\"";} ?>>&nbsp;not used</label>
Andrew Read
Values should be "" rather than NULL.. oops :)
          <input type="radio" name="SCRUBNAME" id="SCRUBNAME__3" value="" class="formRadioField_Standard" <?php if (!(strcmp((isset($_GET["SCRUBNAME"])?$_GET["SCRUBNAME"]:""),""))) {echo "checked=\"checked\"";} ?>>&nbsp;not used</label>        __________________
                Andrew Read
Read Consulting Services        [IMG]https://www.webassist.com/forums/images/buttons/edit.gif[/IMG]
I have submitted a feature request to our system for this.
Andrew Read
A clear all fields button on the search form would also be a good addition or solution (although less targeted than the radio button approach.)
Andrew Read
Is there a nifty bit of code that will clear the search criteria that is in the back of your head? That would be a great button to add to those search forms. ;)
see this page for details on creating a script to clear form fields:
clear-form/
