Uploading Live
Thread began 7/24/2012 2:41 am by daniel387105 | Last modified 7/24/2012 12:34 pm by Jason Byrnes | 789 views | 1 replies |
daniel387105
Uploading Live
Hi there
I have set up my power store and products, what is the best way to upload and install live.
Should i just export the databass with same pass ext and inport the databass and upload all files?
also please see shop/ for another error
It is best to install it from scratch on the live server rather than install and configure it locally then upload it.
If you install and configure it locally, then upload to the live server, you will need to make sure to retain the same folder structure from the local server on the live server.
In other words, it looks like you installed it to:
Anpa Store/
on the local server, you will need to upload it to:
Anpa Store/
for it to work correctly remotely.
It also looks like you have made some modifications to the power store index file that is the cause of the error you are reporting.
the error is reporting a problem in the CSSMenuWriter/cssmw_home/menu.php file, this is not a file that is in power store.
