Spry tabbed panels and clients
Is there any way to allow clients to be able to add/remove tabs (and associated content) in a tabbed panel set up?
Jamie
Jamie
No, power CMS Builder does not offer support for adding tabs to Spry Tabbed Panels.
If I'm understanding correctly... similar to what you're trying to accomplish, I've had success allowing clients to add-to and subtract-from existing accordion widgets. It takes a little educating and a brave client, but I imagine its similar to a tab situation. At worst, there is a bit of diving into the source code through the html editor on their end that can be done to ensure all is right before publishing.
thanks to you both...
@MikeyT - I thought that would be the only way but thought I would check first!
Jamie
