MSQL Error
Thread began 7/22/2012 3:09 am by daniel387105 | Last modified 7/24/2012 1:42 am by daniel387105 | 1146 views | 2 replies |
daniel387105
MSQL Error
Hi there
my powerstore was all set up and working and doday i have gone to open the page and i get this error, can someone please help asap
Warning: mysql_pconnect(): An attempt was made to access a socket in a way forbidden by its access permissions. in C:\xampp\htdocs\Anpa Store\Connections\PowerStoreConnection.php on line 9
Fatal error: An attempt was made to access a socket in a way forbidden by its access permissions. in C:\xampp\htdocs\Anpa Store\Connections\PowerStoreConnection.php on line 9
in the Connections\PowerStoreConnection.php file, what is the Host address set to? try using localhost
It could also be a fire wall issue, try turning any firewalls you have installed to see if there is a fire wall conflict.
als try checking this page for details:
an-attempt-was-made-to-access-a-socket-in-a-way-forbidden-by-its-access-permissions-make_sock-could-not-bind-to-address-0-0-0-080/
daniel387105
Thanks Jason you was correct as always its been added to the firewall :)
