Quantity Discount Help
Thread begun 7/19/2012 1:29 pm by psychobilly1165508 | Last modified 7/23/2012 7:35 pm by psychobilly1165508 | 1425 views | 2 replies |
psychobilly1165508
I have a quantity discount column in my database to group various products for certain discounts.
Number of Items where "qtydiscount" has value of "1" is equal to a value of "2"
Calculation = Flat Rate = $9.98
What I have, works perfect. But I need to multiply the discount based on multiples of 2.
Example:
if 4 items were in the cart, it would deduct $19.96
if 6 items were in the cart, it would deduct $29.94
and so on...
I can't seem to figure out the logic on this. Thanks
code:
//eCart Rule
function WAEC_ssdcart_QuantityDiscount() {
$totalDiscount = 0;
if (true && (($this->ConditionalTotal("Quantity", "qtydiscount", "1") == 2))) {
$totalDiscount += 9.98;//Result
return WA_eCart_FormatNumber($totalDiscount, $this->ForceDecimalsC, $this->DecimalPlacesC);
//eCart Rule
set the trigger to number of items where qtydiscount = 1 is >= 2
then use this code in the flat rate calculation:
9.98 * ceil(($this->ConditionalTotal("Quantity", "qtydiscount", "1") - 1) / 2)
psychobilly1165508
ok, thanks
