Clarification needed for validating forms
Thread began 7/17/2012 2:38 pm by jon211112 | Last modified 7/21/2012 3:10 pm by jon211112 | 438 views | 2 replies |
jon211112
Hi there
I'm using the latest Data Bridge (1.0.5) with DW CS6 on Mac OSX in case this is relevant.
I have a registration form and am wanting to validate it for certain criteria:
1. Email address is in the email format
2. Two password fields match
3. The email address is not already in the database
I'm really struggling with how the logic works and the documentation isn't helping.
I've used the WA Server Validations behaviour and put in my validations but I'm not absolutely clear how I should set it up although I 'think' I've done it correctly.
I've then written an error message and used the Validations...Show If for the line but this is where I'm really struggling.
Can you give me some information on how this actually works? When I think I've done it right, the message shows all the time. Then I change it and it never shows. I'm wondering if the form is submitted, the validation prevents the record from being inserted but the error is lost?
Some comprehensive info on this would be really helpful. I've also searched these forums to try and find the answer.
Many thanks
Jon
In the server validation behavior, set up 3 validations:
Select email address validation type, for the Server Variable, click the lightning bolt icon, and select the email address form element
Select Like Entry validation type, for the server variable, click the lightning bolt icon and select the password form element. Click the plus button to add it to the list of validation, this will open a prompt for you to select the comparison element, select the password confirm field.
Select Unique Database entry validation type, for the server variable, select the email address element. when you click the plus button, select the table to use and the unique column.
Set the key column to the Primary key column, and leave the key value at 0.
to show validation error messages on the page, type the error, select it then go to WebAssist -> Forms -> validation -> Validation show if. select the validation that should fail to show the error message, and click the plus button to add it to the conditions.
One thing to bear in mind wit this is that the validation failure is stored in a session.
this means that if the form fails validation, you browse to another page then come bucket the form page, the validation error messages will still show.
the validation failure wont be cleared until the validation passes.
jon211112
Thanks Jason. That's perfect.
I think the key thing I hadn't realised was the session variable being set. I kept seeing a message when I hadn't submitted the form. Now I understand that it's behaving exactly as it should.
Huge thanks. You've save me from going round in circles!
Cheers
Jon
