Using maps in tabbed panel
Hi guys
Got a slight problem with a map.
Have set up a tabbed panel with 2 panels... one for each map.
The first tab displays the map absolutely fine (see map1.png)
However, when you select the 2nd tab, the map isnt fully displayed (see map2.png) - its displaying the right map but just not centring it correctly (see map2-2.png which is basically map2 but have dragged the centre of the map down)
Cheers
Jamie
