main css
Hi
I would like to know where to change the main css for as the customer wants a black aand crey website so i need to change everthing?
Hi
That is a rather generic question that does not have a specific answer. to create a "black and Grey website" there will be many places that you will need to edit.
If you are using Power Store 4.5, there is a design editor in the Admin Panel that will allow to make changes to the design of the web site, other wise, you will need to edit the css.
I suggest using a tool like Fire Bug in Fire Fox to access the CSS for an element directly in the browser to easily find the CSS that effects a specific element, see this article for details on using Fire Bug:
roadmap_10.php
HI Jason, its ps3 so i have to edit the main css, i will have a look in to the and again thanks for your time.
Daniel
Fire bug will help in finding the css that needs to be edited.
