Filemanager data question
Thread began 7/16/2012 1:20 pm by info343681 | Last modified 7/17/2012 7:14 am by Jason Byrnes | 553 views | 1 replies |
info343681
I am using File Manager, packaged with HTML Editor, and want to capture data about the images the user uploads to the server, i.e filename, path.
I will then use this data to populate database fields for catalog information.
Is this possible, and if so what files/code pages will I need to use.
Thanks for any help offered.
When you add a file manager to your form, there will be a binding in the form binding group for the file manager field.
This binding will return the server relative path to the uploaded file, for example:
/images/filename.jpg
