Yet another Bug, cookies this time
Thread began 7/16/2012 3:18 pm by dvolle228412 | Last modified 7/16/2012 3:53 pm by Jason Byrnes | 1509 views | 1 replies |
dvolle228412
I wish just once that I could use a web assist product that wasn't completely crawling with bugs.
I have Data Bridge 1.05 (You should be honest and call it beta 0.05)
I used the webassist menu in dreamweaver to dispaly a cookie via javascript and your software inserts a javascript include for your cookie.js file at the very top of the code page above all the php code.
IT SHOULD BE OBVIOUS that javascript cannot work when inserted before the doctype, and that it will also crash attempts to parse php when it is intermingled with javascript by WebAssist!
Please inform when the next version that will maybe actually work will be available.
I am not able to reproduce the problem that you are reporting.
Please send a copy of the page you are adding the Show Cookie Value with Javascript behavior to so i can look at the code.
If you could also let me know what version of Dreamweaver you are using and your OS< that will help us in trying to find the cause of the problem.
