Won't Install
Thread begun 7/15/2012 12:30 pm by snap320984 | Last modified 12/01/2014 11:39 am by Jason Byrnes | 3338 views | 6 replies |
snap320984
Won't Install
I upload all the files and navigate to the install.php page - this automatically launches the next page in the /install_gallery/index.php which has a button link on it "get started". When I click on it, nothing...it won't go any further. If I put the entire URL in pointing to the diagnostic.php page - of /install_gallery/diagnostic.php it just bounces back to the index.php page and the get started button.
help???
most likely the problem is that the server is not storing session variables correctly.
to test the server for session management, use the sessionTest.php file from the following thread:
showpost.php?p=23826&postcount=2
if the session test fails, it is most likely the session.save_path setting in the php.ini file, contact your host to have them correct the problem.
snap320984
Null
Ok, so it did come back Null - what exactly do I need to tell or ask the host to fix?
show the host the session test script.
it is most likely the session.save_path setting in the php.ini file that needs to be corrected.
snap320984
Session Management
Got it fixed! That was it...so far, thanks
info72555
Cannot download test file
the link to the ZIP file you are referring to does not download for me. The cursor turns into an arrow but nothing happens when I click
Here it is attached to this thread.
