image file location incorrect on image update
Thread begun 7/15/2012 8:38 am by asarcona308398 | Last modified 7/16/2012 7:48 am by Jason Byrnes | 1241 views | 1 replies |
asarcona308398
I'm having a problem with an update of a database record that uses an image,
I followed the direction of using a hidden file field in the update page, and using that file field in the upload file server behavior and it does work
---> Only it is also including the folder I specified as the save to folder in the original file upload --> ../images/staff a second time on the update
So in reality I'm getting ../images/staff../images/staff/bear.jpg in the database column after the update.
the image is also being resized, I don't know if this is having an effect on the file directory
I've included the offending file!
the problem is happening because you are storing the location along with the image name, instead of just storing the file name.
You should not store the location in the database, only the file name.
the location reference will change on a page by page basis. so you should specify the location on the page where you display the image using the image tag, rather than store the location in the database.
