Pro Maps API V3 Problem
Thread begun 7/14/2012 8:57 am by Mike Perry | Last modified 7/17/2012 10:11 am by Mike Perry | 4363 views | 11 replies |
Mike Perry
I'm trying to update a Pro Maps to V3 of the API. Using Design Extender 1.09.
When I include directions, the location pin and info window for the map does not display. Firebug reports that map1 is undefined. When I leave the directions box unchecked, the pin and info window display properly,
Directions don't work when I include directions -- the starting address data is passed to the posted page in the URL, and Firebug reports that map1 is undefined.
Files (page & google_javascript folder) are attached.
cincinati_apiv3.php is the page where directions is left unchecked, and cincinati_apiv3_2.php is the page where directions is checked.
Thanks. . .
Mike
Dave BuchholzBeta Tester
I have seen this when updating an existing google map, I just went in and hand edited the files to change the reference
Mike Perry
Originally Said By: Dave Buchholz
Hi Dave:
First -- what code did you change, and what did you change it to?
Second -- what if I'm creating a new map, starting clean with no existing references to Google Maps or WA code??
I dont see any old Google Map code on your page, but the links you provide don't seam to work.
Can you give correct links so i can investigate the problem.
one thing that may be causing the issue is using "directions" as the form name, try using a different name for the form.
<form action="cincinnati_apiv3_2.php" method="get" name="directions">
also try changing the id of the "address" div:
<div id="address">
Mike Perry
<div id="address">
Oops.
cincinnati_apiv3.php and cincinnati_apiv3_2.php
Pretty bad when I misspell my home town. . .
Will try your suggestions and reply back.
ETA: No joy changing the div id or form name. . .
This is caused by a bug in the map code when using more than one map in your site, i have logged this in our system to be corrected in the next update.
to correct the problem, for now, find the following code in the webassist/google_javascript/wagmp_map_2.php file:
directionsDisplay.setMap(map1);
directionsDisplay.setPanel(document.getElementById("wagmp_directions_1"));
and change it to:
directionsDisplay.setMap(map2);
directionsDisplay.setPanel(document.getElementById("wagmp_directions_2"));
to fix the issue with the markers not showing, find each instance of:
MarkerImage('google_javascript/
and change it to:
MarkerImage('webassist/google_javascript/
Mike Perry
and change it to:
and change it to:
Thanks, Jason. . .
What's a rumpas??
A rumpas is a noisy disturbance, according to dictionary.com:
rumpus
When made king of the Wild Things, Max cries "Let the wild rumpas start!"
Where_the_Wild_Things_Are
Mike Perry
rumpus
That's what I thought -- but I didn't want to assume. .
Mike Perry
New Issue
The markers now show.
However the map now displays with the default start point (somewhere in Kansas) instead of the default address showing at the center of a more local map, and the directions to the address from that point.
Also cannot edit the map -- I get a "pathtoURL" error, which I presume comes from the change in paths to the markers.
Thanks. . .
