shipping and discounts
Thread began 7/12/2012 11:48 am by sam308940 | Last modified 7/12/2012 4:45 pm by Jason Byrnes | 390 views | 4 replies |
sam308940
I have a shipping rule, >$30 shipping is free.
and i have a discount code that gives 50% off products.
however if the subtotal is $50, and the discount is $25, the balance is $25, but the cart is still giving the free shipping. I realize its all based odn subtotal.
so..... how can i get the shipping to take the subtotal-discounts to determine if shipping is free?
theres no way to do this in the wizard right?
In the shipping rule use the trigger "Subtotal for Any Colum":
If the Subtotal for Column "TotalPrice" < 30
to apply the shipping based on the Total Price before discounts.
sam308940
That fix DID NOT SOLVE the problem.
the discount is 50% off the subtotal.
so its not calculating per item?
so by calculating the shipping on the column - that doesnt change anything.
is there a way to just make the shipping calculation use IF (SUBTOTAL-DISCOUNT-TOTAL) <30 ?
sam308940
experimenting with the code, i changed
$this->TotalColumn("TotalPrice") to $this->GetTaxableTotal()
(full code below)
this seems to function as i want it.
any reason I should not do it this way? errors ?
//eCart Rule
function WAEC_sbd_Shipping() {
$totalShipping = 0;
if (true && (($this->GetTaxableTotal() < 30))) {
$totalShipping += 10;//Result
return WA_eCart_FormatNumber($totalShipping, $this->ForceDecimalsC, $this->DecimalPlacesC);
//eCart Rule
That should be fine, that would be the same selecting to use the trigger, taxable total for the cart.
