Trouble with sizePriceInc and productPriceInc in Product Options
Thread began 7/11/2012 6:42 am by Rune Brynestad | Last modified 7/11/2012 11:40 am by Rune Brynestad | 750 views | 4 replies |
Rune Brynestad
I have followed the Product option tutorial for eCart. As you can see in the attached Picture 1 there are two problems. The color (Farge) shows in the cart with ProductOptionID not the OptionName. The price column (Pris) shows the standard price, not the incremented price (210 should be 214). However the Total column shows the correct price, 214.
I believe the display color problem could be solved with both the Label and the Value setting to use the Option name column. The results shows in the attached Picture 2. The color displays with the Option Name as it should, But both Price and Total shows the standard price, not the incremented price (210 should be 214 in both cases).
To solve the incemented problem I have tryed to add the increment to the select list like this:
<option value="<?php echo $row_rsColor['OptionName']?>"><?php echo $row_rsColor['OptionName']?><?php if($row_rsColor['OptionPriceIncrement'] > 0) echo(" + ".$row_rsColor['OptionPriceIncrement']); ?></option>
But nothing is changed in the cart.
You can test it on live URL here: products_detail.php?ProductID=22
The color (farge) menu is the last one. Try either Red (Rød) or Brown (Brun)
I'm attaching the cart and the product detail pages. I'm also attaching the WA_eCart/TcaCarcare_PHP.php page and the WA_eCart/WA_eCart_Definition_PHP.php page so you can see how the cart is configured.
Thanks in advice
Regards
Rune
eCart.zip
when dealing with options that effect the price, there are a couple of key ideas to keep in mind:
1) In the add to cart behavior, don't set the Updatable From Select list option for that column, only do that if the option does not effect price.
2) you need to manually add the select list after the add to cart button is added to page. The select list should be set to use the Option ID as the value. This will be used to filter a lookup recordset.
3) After you have created the select list and lookup recordset, you will edit the add to cart behavior to bind the Option column and the pricer increment column to the corresponding columns in the lookup recordset.
In your setup, it looks like you set the updateable from select list option for the color column, and this is why it is not working.
when the option effects price, you need to use the lookup recordset to get the option name and price increment values into the cart.
Rune Brynestad
Thanks for your quick reply.
I have been through the checkpoints and it looks better now.
The only problem left is that the price column (Pris) shows the standard price, not the incremented price (210 should be 214). Total column shows the correct price, 214. See my attached picture.
Live URL here: products_detail.php?ProductID=22
I'm also uploading a new version of the product detail page.
Thanks again
Regards
Rune
products_detail.zip
in the cart display, make sure to edit the price to show the True Price calculation instead of the Price column.
Rune Brynestad
Works perfect now.
Thanks again for looking into this.
Regards
Rune
