Server Side Validation Fail - PHP Self vs REQUEST URI
Thread begun 7/10/2012 11:42 am by Ian S | Last modified 7/10/2012 12:22 pm by Ian S | 2846 views | 2 replies |
Ian S
Hi Guys,
Just a quick question which I think I know the answer to, but just wanted to check.
Your extensions use PHP_SELF for things like referring failed validations back to itself if no redirect is set. I had problems with this on a site where the form was on a rewritten URL.
However, I simply changed PHP Self vs REQUEST URI and that solved my problem.
Am I right in thinking that the only reason this isn't good is because it doesn't work on IIS? Or are there other pitfalls I should take into consideration?
Cheers
Ian
we don't use Request URI because it is not universal, like you mention, it is not present in IIS.
That is pretty much the major downfall.
To be honest, I don't like to leave the faed redirect blank, it's better to specify the failed redirect and include a querystring variable to use as a flag for the initial value.
Ian S
Thanks for the reply Jason,
Yes, I usually set a ?fail=1 for a failed validation but in this instance as I need to retain the friendly URL I think I am going to have to use Request URI (its being hosted on Apache) and the Validation Session to control the messages.
Cheers
Ian
