PDF for digital file pro
Thread began 7/09/2012 12:48 pm by Patrice | Last modified 7/09/2012 1:49 pm by Patrice | 954 views | 2 replies |
PatriceWebAssist
dfp_da_insert_update_ht.pdf
Is page 4 accurate? I realize where to find new "file manipulation" change due to new name, but on this page, I am trying to get the update page to have the file uploader. Reading this indicates that "applying digitial file pro" goes back to the insert page, not the update page.
Next you will want to apply the Digital File Pro Upload behavior to your new file field.
10. In Dreamweaver, open the Insert page.
Should step 10 on page 4 be "open the Update page"?
I was able to do the insert page directions but am stuck on the update page instructions.
Also, when you get to updating these tuts, if there would be a screen shot of how to find/do page 2 and 3 of Updating the Insert Server behavior, ie, step 21 "expend WA upload file" that sure would help. There is not Step 2 or Next in this area at this point. I muddled thru and finally found it but I'll be hard pressed to figure it out again.
Thanks.
Yes, step 10 on page 4 should be the update page.
I'll pass your comments along.
PatriceWebAssist
Thanks Jason, as always. I'll try again to figure out the updater.
