UE Error: "open <%=not closed"
Thread began 7/09/2012 12:34 pm by Paul | Last modified 7/09/2012 1:22 pm by Jason Byrnes | 670 views | 1 replies |
PaulBeta Tester
I've created a new registration page where an email is required to send after a new record is inserted.
I'm using the 'edit' function in the UE wizard to create my email content. Below is what i have added
<a href="http://www.houseyfied.com/hf1/joiners/confirm.php?UID=<?php echo (mysql_insert_id());?>&ID=<?php echo(ValidatedField("regform1_314","HOValid")) ?>&TID=<?php echo
ValidatedField("regform1_314","ClientStatus")) ?>"> click here to complete the account setup.</a>
When i 'OK' it, then click 'Finish' to save and close the wizard, the attached error appears, which unfortunately is preventing my changes from saving.
(Only non PHP plain text will allow to save and close without this error)
Any ideas please?
for one, you shouldn't be using the validated entries bindings in the email message, you should be using the form element bindings instead.
