Wizard error
I getting this when I navigate to the Power CMS Index page.
The Installation wizard with the button surrounded by
=========================This Info===================================
Warning: session_start() [function.session-start]: open(/var/chroot/home/content/p/i/p/pipwax2/tmp/sess_8u0q1arjvhvcfkkg3rb3vmt4j6, O_RDWR) failed: No such file or directory (2) in /home/content/p/i/p/pipwax2/html/CMS1/install_cms/global.php on line 2
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at /home/content/p/i/p/pipwax2/html/CMS1/install_cms/global.php:2) in /home/content/p/i/p/pipwax2/html/CMS1/install_cms/global.php on line 2
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home/content/p/i/p/pipwax2/html/CMS1/install_cms/global.php:2) in /home/content/p/i/p/pipwax2/html/CMS1/install_cms/global.php on line 2
PowerCMS Installation Wizard
Welcome to the PowerCMS Installation Wizard. This wizard allows you to quickly configure PowerCMS to work on your live server. Once completed, your content management system will be installed and ready for you to use with your website.
Get Started
Warning: Unknown: open(/var/chroot/home/content/p/i/p/pipwax2/tmp/sess_8u0q1arjvhvcfkkg3rb3vmt4j6, O_RDWR) failed: No such file or directory (2) in Unknown on line 0
Warning: Unknown: Failed to write session data (files). Please verify that the current setting of session.save_path is correct () in Unknown on line 0
================================end==========================
then when I click the button I get this
====================================second page after button=============
Warning: session_start() [function.session-start]: open(/var/chroot/home/content/p/i/p/pipwax2/tmp/sess_vpkr629rsse932av2nnr804f17, O_RDWR) failed: No such file or directory (2) in /home/content/p/i/p/pipwax2/html/CMS1/install_cms/global.php on line 2
Warning: Cannot modify header information - headers already sent by (output started at /home/content/p/i/p/pipwax2/html/CMS1/install_cms/global.php:2) in /home/content/p/i/p/pipwax2/html/CMS1/install_cms/wizard.php on line 44
Warning: Unknown: open(/var/chroot/home/content/p/i/p/pipwax2/tmp/sess_vpkr629rsse932av2nnr804f17, O_RDWR) failed: No such file or directory (2) in Unknown on line 0
any help determining what I may have done incorrectly would be helpful.
