Authentication problem UE CDOSYS_JS
Thread began 7/05/2012 9:05 am by rcarline237430 | Last modified 7/06/2012 11:59 am by Jason Byrnes | 560 views | 1 replies |
rcarline237430
I have recently changed OS from XP to Windows server 2003. I have also installed a new SMTP server. The website I am hosting sends email to users when registering and making purchases. Since the changeover all pages with Universal Email sending to external domains are returning the error '8004020f' failure to send. Emails sent internally using the same code are fine. I can also send to external domains using outlook.
On checking the SMTP conversation log it appears the problem is "relay denied" because authentication is failing, as if the login credentials are not being sent to the server from the webpage. Everything was working fine before the changeover but now UE has stopped working.
in the new SMTP server, is the same user email defined with the same password that you used to use?
It sounds like something has changed in the SMTP server configuration that is causing the problem
In Universal Email, have you set the behavior to pass authentication?
Double check the username and password that are being used.
