Featured Pod not aligned
Hi, I'm using the default theme and after editing the content of the Header for the Featured Pod, the text has dropped down so that it no longer aligned with the other boxes.
How can I fix this?
How can I fix this?
in the webassist/plugins/caltalog/featuredbox.php file, change:
<h1><?php echo WA_getCMSContent($database_PowerStoreConnection, $PowerStoreConnection, 'Featured Pod' , 'Header'); ?></h1>
<h1><?php echo str_replace(array("<p>","</p>"),"",WA_getCMSContent($database_PowerStoreConnection, $PowerStoreConnection, 'Featured Pod' , 'Header')); ?></h1>
in the webassist/plugins/popularbox.php file change:
<h1><?php echo WA_getCMSContent($database_PowerStoreConnection, $PowerStoreConnection, 'Popular Pod' , 'Header'); ?></h1>
<h1><?php echo str_replace(array("<p>","</p>"),"",WA_getCMSContent($database_PowerStoreConnection, $PowerStoreConnection, 'Popular Pod' , 'Header')); ?></h1>
and in the webassist/themes/defailt/templates/index.dwt.php file, change:
<h1><?php echo WA_getCMSContent($database_PowerStoreConnection, $PowerStoreConnection, 'Middle Pod' , 'Header'); ?></h1>
<h1><?php echo str_replace(array("<p>","</p>"),"", WA_getCMSContent($database_PowerStoreConnection, $PowerStoreConnection, 'Middle Pod' , 'Header')); ?></h1>
