eCart Clear Cart button set to remove any present promo codes, coupons
Thread began 7/05/2012 11:28 am by graham | Last modified 7/05/2012 9:31 pm by graham | 469 views | 3 replies |
graham
Happy Independence Day, Webassist - looks like you have your work cut out for you with new threads :o)
Adding to the queue ... a quick one for you ... can (should?) the eCart Clear Cart button be set to eliminate any promo codes in effect when pushed? I think I would like the shopper to start with a blank cart - any thoughts/instruction?
add a clear session behavior to the cart page.
on the server behaviors panel, click the plus button and select Webassist -> Cookies -> Clear Session Values
For the trigger, select the Clear Cart button pressed.
From the list of sessions to clear, select the promo code session.
graham
Will try ... thanks for quick reply!
I will try now.
graham
Resolved
Works like a charm ... thanks!
