site import not working in CS6
Thread begun 7/04/2012 10:16 pm by info386262 | Last modified 8/13/2012 8:50 am by Jason Byrnes | 6145 views | 9 replies |
info386262
Just got a new mac and added the site import extensions to Dreamweaver cs6. Everything looks normal but when i click on site import nothing happens. Been waiting for and hour with nothing happening in the processing bar.
What is the URL for the site you are trying to import?
make sure that the path your trying to import the site to is a part of a site that is defined in Dreamweaver. Your import path should be to import into a Dreamweaver site.
info386262
unable to site import
I have tried on my own site stevcollins.com.au as a test but doesn't work. I have done this many time in the past. I have attached the error messages when i open up Dreamweaver, which has to do with memento.
Rest the Workspace layout by going to Window -> Workspace -> Reset '<Your layout Name>'.
then Delete the Dreamweaver Cache file from the users configuration folder:
common_installation_issues.php
info386262
site import
Hi I have done what you instructed and I now have no error messages. Thanks!
I tried testing site import on a single page from stevecollins.com.au and it lists the WAimportlog.txt into the new directory, but it doesn't download the relevant files. It has been running for 30 minutes with no progress indicating it was trying to work.
info386262
Siteimport
Yeh, I have the location folder placed inside a site a site that is defined in Dreamweaver. Noting happens accept the import log. I have used site import for years and is not responding like it normally does.
info386262
site import solved
just to let you know, I reinstalled Dreamweaver and site import is now working again!
Ok, glad to hear it is working.
