Error in SA Secure Page Behaviour
Thread began 7/02/2012 3:19 pm by Paul | Last modified 7/03/2012 3:02 pm by Paul | 1464 views | 4 replies |
PaulBeta Tester
I'm using SA's Secure Page behaviour to lock down a client area page.
The behaviour inserts the following
if (!WA_Auth_RulePasses("Logged in to member_tbl")){
WA_Auth_RestrictAccess("../../login.php");
However, if i attempt to access this page without logging in, the following error is produced;
Warning: Cannot modify header information - headers already sent by (output started at /home/public_html/hf1/members/portfolio/MyPortfolio.php:1) in /home/public_html/hf1/webassist/security_assist/helper_php.php on line 77
I've also noticed two WA Security Assist folders in my root directory
WA_SecurityAssist
and
security_assist
The file helper_php.php exists in the latter and Helper_PHP.php in the former.
I have attached the page this affects.
Any ideas what is going wrong and how can it be resolved please?
MyPortfolio.zip
Ian S
First thing to try is to remove the blank space after the closing PHP tag of the code you posted above. i.e. Delete the space after ?>
Cheers
Ian
PaulBeta Tester
Thanks for response
Unfortunately that hasnt resolved.
The issue seems to be linked to
if($row_UserLock['hoAdminGlobalLock'] == "0") {
header("Location: ClientAreaLocked.php");
    exit;
In my login page
Because if i set the lookup value in my table to "1" the error does not ocurr
Paul
see this thread for details on troubleshooting the Headers Alredy sent error:
showthread.php?t=19285
the error is reporting the output at line 1:
so pay atention to the section at the end where i talk about the Unicode Signature (BOM) PHP Bug.
PaulBeta Tester
This was very helpful.
Thankyou.
