Add to Cart
Thread began 7/02/2012 5:22 am by johna1964 | Last modified 7/03/2012 2:35 pm by johna1964 | 2510 views | 10 replies |
johna1964
Add to Cart
I have added some products to my site and have several add to cart buttons on each page.
Using the update version 5.0.6, I am able to add only one item to the cart page from the new buttons generated. All older items continue to function normally, but the new buttons replace whatever new item is in the cart.
I have tried on more than one page and on another testing site; all do the same thing.
Cart page and a static product page are attached.
Let me know if you need any other files...
Thank you so much!
johna1964
Files.zip
please post a link where i can see the problem and steps to reproduce.
johna1964
Hi Jason,
Had to upload it.
Here is a direct link:
coconut.php
I do not want to create links to the page yet, because it is unfinished... this will show you the issue though...
Thank you for your help :)
johna1964
try this:
find the following line on the add to cart page:
header("Location: ".$eCart1->redirStr);
and chAnge it to:
@session_commit();
johna1964
Hi Jason,
I changed it. Did I place this code correctly?
The lines 68-74 now look like this:
// WA eCart Redirect
if ($eCart1->redirStr != "") {
@session_commit();
I uploaded it - it is still not working...
I tried on three pages of the new pages with more than one add to cart button - nothing
Do you need me to upload the WA eCart folder... did I need to add a file since the ecart update?
Please help :)
Thank you!
johna1964
johna1964
Hi Jason,
I tried again this morning on the new site. I placed the code as instructed. It contiunes to replace whatever is in the cart - not adding more than one product to the cart via static pages.
It will however add more than one product when the add to cart button is selected from the data assist pages.
I hope this helps with a solution.
Thank you much for your time and help!
johna1964
The add to cart buttons look to be set up OK, can you send a copy of the WA_eCart/eCart1_PHP.php file so i can see hiw the cart object is configured.
johna1964
Thank you Jason
Here is the file.
I put in a support ticket, but I uploaded the new files (new site) with that, not the one that is uploaded here...
It may be the same problem so if one is solved the other will be too... hopefully :)
johna1964
eCart1_PHP.zip
I think I'll need to troubleshoot this on your server.
johna1964
Jason,
I have responded to the support ticket.
Thank you!!
johna
