Result page
Thread began 6/29/2012 3:45 am by Noa2086 | Last modified 6/29/2012 7:32 am by Jason Byrnes | 552 views | 1 replies |
Noa2086
Result page
i would like to have a result page, after i trigger the submit button with the previous entered data.
For example:
form.php -----> send data with session id to -----> result.php
(and store in the database)
Does it have a "get content from form" button?
I work with a database. How can i display the current created ID from the table in the URL?
How can i do that in detail?
Thx for your quick help!
Use the Data Assist insert record server behavior to save the form information.
In the Data Assist insert record behavior, There is a section of the First screen titled Session Variable, this allows you to select the ID column, and set the name of the session variable that will be used to capture the inserted ID value.
you would then need to add code after the Insert behavior to redirect to the results page using the session variable value, for example, if the session variable is named ItemID:
if($_SERVER['REQUEST_METHOD'] == "POST") {
header("Location: results.php?id=".((isset($_SESSION['ItemID']))?$_SESSION['ItemID']:"")."");
