Adding a Session variable
On the login form, how do I add a cookie upon successful login that is the value from the user table?
I am using the default pcms2_users and want to set the UserGroupID.
edit the Authenticate user server behavior on the login page. To edit the serer behavior, go to Window -> Server Behaviors to open the server behaviors panel, in the list of server behaviors, double click the Security Assist Authenticate User server behavior.
On the session tab, click the plus button, and select the UserGroupID column.
