Apache Xampp DB problem
Thread began 8/03/2009 12:56 pm by mustang_sally_85344510 | Last modified 8/04/2009 2:19 pm by Eric Mittman | 2440 views | 3 replies |
I have instaled Xampp into my computer and cannot get a connection in DW to the PHP database. Are there any other tutorials on this type of connection/server issues? The tutorial I found focuses more on windows server environment. :( Thank you in advance.
What are the values you are using for your connection (minus the password) and what is the error you are getting in DW? It is usually a straight forward process to connect to the db from within DW. You would start by defining your site including the testing server, then with a page that has been saved to that site open go to the Database tab of the application panel.
From here add a new database connection. You will just need to supply the host, localhost should work if it is local, username and password. You will often connect with the root user on a localhost, then the password should be whatever it was set to during the setup.
xampp connection resolved
The computer I originally set up all of my connections with, got hit by lightening and I had to go to a different computer and setup everything again. I was trying to use an old connection. Once I deleted the existing connection, and created a new one the issue got resolved. Thank you for you help!
That is good to hear, sometimes you just need to redo things to get them working.
