Can we use a tracking system (audit trial)?
Thread begun 6/26/2012 1:53 pm by Zulian | Last modified 6/27/2012 7:29 am by Jason Byrnes | 1164 views | 1 replies |
Zulian
Hello Jason,
Is it possible to use a tracking system with Security Assist, I mean to record login info such as name, date/time, ip and what he did with the session, such as ADD/UPDATE/DELETE with the table name?
Also can you update the Security Assist with user access level / and access permission based on tables, which means;
there can be two table to server for this, one table for access groups and another for access permissions, after creating a group with CRUD permissions (such as add/update/delete/search) on table level (should define to which tables this group can access, and when creating a user, we can define hat the user can do (add/modify/delete/search) and on which tables based on permissions roles on user group level.
I am sorry for this bad explanation, but I hope you will get a basic idea on what I am talking about.
Thank you
Zulian
an audit system like you are talking about is really just inserting a record to a database whenever the user performs an insert, update or delete.
create a table to record the information.
on the insert update and delete pages, add an insert record behavior that will store the IP, and other info you would like to track. On the insert page, set the column that tracks the action to ADD, on the update page, set the tracking column to update etc...
in the archived documentation section of the security assist support page, there is a tutorial of user level authentication.
