Has check unique been fixed in 1.0.5?
Thread began 6/25/2012 11:11 pm by Andrew Read | Last modified 6/27/2012 1:10 pm by Jason Byrnes | 550 views | 3 replies |
Andrew Read
I just finished a page with 1.0.4 (didn't see 1.0.5 come out!) and it seems that it is not checking for unique fields correctly. I have at least one that gets through before it is checked and the database bounces it.
We have not encountered bugs with Check Unique validation in 1.0.4.
If you are having problems with the check unique validation, please send a copy of your page so I can examine the code.
Andrew Read
Hi Ray,
I believe these are the parts you require:
This code happens BEFORE the insert behaviour.
if ((isset($_POST["Insert_x"]) || isset($_POST["Insert_x"])))  {
$WAFV_Redirect "".(htmlentities($_SERVER["PHP_SELF"], ENT_QUOTES))  ."?invalid=true";
$_SESSION['WAVT_sitepagesinsert_Errors'] = "";
  if (
$WAFV_Redirect == "")  {
$WAFV_Redirect $_SERVER["PHP_SELF"];
$WAFV_Errors "";
$WAFV_Errors .= WAValidateRQ((isset($_POST["page_name"])?$_POST["page_name"]:"") . "",true,1);
$WAFV_Errors .= WAValidateRQ((isset($_POST["page_vis"])?$_POST["page_vis"]:"") . "",true,2);
$WAFV_Errors .= WAValidateRQ((isset($_POST["page_title"])?$_POST["page_title"]:"") . "",true,3);
$WAFV_Errors .= WAValidateRQ((isset($_POST["page_link"])?$_POST["page_link"]:"") . "",true,4);
$WAFV_Errors .= WAValidateUnique(("site_adm"),$site_adm,$database_site_adm,"site_pages","pageID","none,none,NULL","0","page_link","',none,''","".((isset($_POST["page_link"]))?$_POST["page_link"]:"")  ."",true,5);
$WAFV_Errors .= WAValidateRQ((isset($_POST["page_linkName"])?$_POST["page_linkName"]:"") . "",true,11);
$WAFV_Errors .= WAValidateRQ((isset($_POST["page_order"])?$_POST["page_order"]:"") . "",true,6);
$WAFV_Errors .= WAValidateRQ((isset($_POST["page_body"])?$_POST["page_body"]:"") . "",true,7);
$WAFV_Errors .= WAValidateNM((isset($_POST["page_metaRevisit"])?$_POST["page_metaRevisit"]:"") . "",1,365,0,",.",false,8);
$WAFV_Errors .= WAValidateRQ((isset($_POST["page_parentID"])?$_POST["page_parentID"]:"") . "",true,9);
$WAFV_Errors .= WAValidateRQ((isset($_POST["page_editDate"])?$_POST["page_editDate"]:"") . "",true,10);
  if (
$WAFV_Errors != "")  {
PostResult($WAFV_Redirect,$WAFV_Errors,"sitepagesinsert");
This is after and within the form:
<li class="formItem">
            <div class="formGroup">
                  <div class="lineGroup">
                     <div class="fullColumnGroup"><label for="page_link" class="sublabel" >Page Link Name:<span class="requiredIndicator">&nbsp;*</span></label>
                          <div class="errorGroup">
<div class="fieldPair">
                       <div class="fieldGroup">
                                        <span id="page_link_Spry">
                       <span>
  <input id="page_link" name="page_link" type="text" value="<?php echo((isset($_GET["invalid"])?ValidatedField("sitepagesinsert","page_link"):"")); ?>" class="formTextfield_Large" tabindex="5" onBlur="hideServerError('page_link_ServerError');">
                                            <span class="textfieldMinCharsMsg">Minimum number of characters not met.</span><span class="textfieldMaxCharsMsg">Exceeded maximum number of characters.</span><span class="textfieldRequiredMsg">Please enter a value.</span>
                                        </span>
                       </span>
if (ValidatedField('sitepagesinsert','sitepagesinsert'))  {
  if ((
strpos((",".ValidatedField("sitepagesinsert","sitepagesinsert").","), "," "4" ",") !== false || "4" == "") || (strpos((",".ValidatedField("sitepagesinsert","sitepagesinsert").","), "," "5" ",") !== false || "5" == ""))  {
    if (!(
false))  {
?><span class="serverInvalidState" id="page_link_ServerError">Please enter a value.</span><?php //WAFV_Conditional site-pages-insert.php sitepagesinsert(4,5:)
                       </div>
                       </div>
If you require more, start a ticket and I'll send you the full pages.
Thanks.
